Boost peaks at 17psi and drops quickly to 12psi and holds
I just installed a manual boost controller. The boost builds quickly, delivery is smoother, but instead of peaking at 17 and going slowly down, it peaks at 17, holds for a bit, then jumps down to 12psi.
I have a GIAC chip. Any ideas why this is happening? Thought? What I should do about it? How much boost do you think I can safely allow?
blown TBB, leaking stock IC end caps, etc.etc.etc.
Pressure check, listen and move your hand around, and if need be use a spray bottle with water and soap so you can see if anything bubbles up..
Locate then fix
Locate then fix
