Boost Spike Issue (PLEASE HELP)
I have a 2000 Audi S4 and recently I just installed a boost gauge that's showing me why I'm probably blew my k03's so many times. My car has a giac chip,bov's,piggie dps, evo intake,borla exhuast, stage 2 stuff. I just purchased piggie's standalone mbc and tcc to kill boost spikes. Is that the way to go, I heard from other's yes, and others no because it will make it worse. So now I'm stuck whether or not to put this in. Can someone just help me out with this because it's making me nuts. THANKS
what would be appropriate to log to determine if the n75 was bad? i assume you can measure its signal somehow, but then would you compare that to requested and actual boost?
so your saying I wouldn't need a mbc and tcc to check for leaks and a bad n75. Even if that was the problem should a mbc and tcc be used
though I was tempted when things were flaky.
Do a pressure test, fix any leaks, and if you're still overboosting, replace the N75.
Things should work at least OK without an MBC. I've never experienced throttle cut. Under the right conditions, my boost can spike as high as 24, but it always settles to 20 or slightly lower.
seems to be before throwing solutions at it. Try logging blocks 114 and 115 with VAG-COM, that will show boost and N75 duty cycle.
bushido
02-23-2008 02:53 PM
Beater
11
10-09-2007 09:48 AM
PSmalls::AnalRetentiveNumbNut
48
10-30-2006 07:49 PM
