Boost Spiking Problem
Hey, i got a 2000 Audi s4, with about 120,000kms, its got a Apr chip and catback and an upgraded diverter valve. Yesterday I installed a AWE boost gauge. Very thing went smooth on the install. Took it for a test drive and it boost perfectly fine topping out at about 10 to 12 psi and a solid 18 to 20 in.Hg vac pressure at ilde.
Today i was driving it and it boosted to 10psi, then shot up to 15 then dropped. when it did this the check engine light started turning on and off. When i stopped my vac pressure was at 10 in.Hg. That continued for a little while. IT was alright later today but it still spikes every so often when i go full throttle any ideas?
Thanks
Jeff
Thanks
Jeff
The car has be performing fine ever since. It kinda strange though when i pull in 3rd it only boosts at about 12 psi, but when i pull in 6th it boosts right to 15?
I dont have a engine diagnostic so i cant give super accurate figures.
I'm goin go around and make sure all the zip ties are tight and all the hoses are good then take er for a for a cruise and try and solve the problem i only had a chance to try and open it up on my way to work so it was a little hard in alot of traffic haha
You will need to run some logs to find the reason for this. VAG blocks 3 and 115 during 3 rd gear WOT run from about 3K to redline. Hopefully you have a VAG (or ECUx).
Bruce
Bruce
ECS Tuning-Audi
A4 (B8 Platform) Discussion
11-30-2016 06:09 AM
ECS Tuning-Audi
S4 (B8 Platform) Discussion
09-09-2015 12:00 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-09-2015 11:51 AM
S4intheOC
09-08-2015 12:12 AM
