bose hidden equilizer functions
To access the Bose hidden EQ functions here are the steps.
<> Turn radio off
<> Press and hold down the 5 and power button
<img src="http://pictureposter.audiworld.com/28085/bose_eq_1.jpg">
Next you will see the following numbers or EQ adjustments
<img src="http://pictureposter.audiworld.com/28085/bose_eq.jpg">
The 3 numbers to the right adjust the treble, then the next 3 adjust the midrange and last 2 balance the bass.You will adjust the numbers higher or lower by turning the volume ****. This is if your reading this from right to left. Once you are done with setting them the way you want to, simply press the on/off button to save into memory. This should give you more dynamic control over your bose symphony system.
<> Turn radio off
i like techno so i adjusted the settings to give me good bass and some high treble with the midrange just giving me enough response. But it wont be long i will be pulling out the Bose speakers and going with my Mb Quarts Rsc213 w/ 2 JL Audio 10w0 and JL Amps..
anyone recommend a good AudioControl EQ for this setup?
also http://www.ibiblio.org/tkan/audi/radios/symphony.html
There have been tons of posts on the EQ settings - search will show lots of examples.<ul><li><a href="http://e-audi.tripod.com/eaudinewsarticles/synfhead1.htm">http://e-audi.tripod.com/eaudinewsarticles/synfhead1.htm</a</li></ul>
These settings are different but each is better than factory. Try them!<ul><li><a href="https://www.audiworld.com/tech/elec56.shtml">https://www.audiworld.com/tech/elec56.shtml</a</li></ul>
