brake question what would you guys pick..........................
stoptech: 355mm x 32mm. the caliper is a 4 piston
<img src="http://www.achtuning.com/images/stoptech/stoptech_both_rotors.jpg">
<img src="http://www.achtuning.com/images/stoptech/stoptech_caliper.jpg">
or
ECS stage 4: 352mm x 32mm. the caliper is a 6 piston.
<img src="http://www.ecstuning.com/stage/images/product/iadmin/1679_x450.jpg">
<img src="http://www.ecstuning.com/stage/images/product/iadmin/1681_x450.jpg">
or you would get the stage 3 from ecs with 322mm 4 piston porsche 993tt brakes. also why are these more expensive than the stage 4. thanks
or
with 13" rotors is only $2795.00
Monobloc caliper= stiffer brakes, better pedal feel.<ul><li><a href="http://www.avalonmotorsports.com/b5s4_brakes.htm">http://www.avalonmotorsports.com/b5s4_brakes.htm</a</li></ul>
<center><img src="http://www.ecstuning.com/stage/images/product/brakes/ECS-Stage4/Caliper-Piston-Sizingv2-790.gif"></center><p>The Stage 4 brakes are very closely balanced with the stock setup. Also, be on the lookout for more pad options. I don't think the fact that the Stage 4 has limited pad selection has gone unnoticed by any means. I would certainly be on the lookout for sometime in the spring/summer for more options. Not to mention that the Stage 4 kit is MUCH less than the Stoptech setup.
