Broken front sway bar bracket bolt, any ideas?
So I noticed one of the bolts on the front, driver's side sway bar bracket is broken. Should I drill it out and tap it for a bigger (10mm?) bolt or should I try to remove the existing one somehow?
2001.5 S4
175k miles
2001.5 S4
175k miles
It's hard to see in the picture - how much of the bolt is exposed? Would soaking it in PB penetrating spray and using a pair if vise grips on it be a viable option? I despise drilling out bolts.
:: www.ECStuning.com :: Now with EXTENDED Customer Service hours!! | FIND US ON FACEBOOK!!![Cool](https://www.audiworld.com/forums/images/smilies/cool.gif)
Phone: 1.800.924.5172 - Sales: 8:30am to MIDNIGHT EST | Customer Service 8:30am - 8pm EST
Questions? PM us for a quick response! | Email: Pete@ecstuning.com
![](https://www.audiworld.com/forums/signaturepics/sigpic191288_1.gif)
Let the penetrating catalyst soak for some time before trying to break it free.
you can also try a reverse threaded drill bit, ez out type tool, or cutting a slot in the exposed bolt and using a flat blade screw driver to remove after pb'ing it up
Former Vendor
Those aren't bolts. They're studs which are pressed into the aluminum. To remove it you either have to press it out, or drill it out.
Best to drill it out, and replace it with a normal nut/bolt combination.
Good call!
I simply tapped it out. The bolt has a round top and is smooth...so now tool will remove it. However, it was simple to replace by dropping in a new bolt which didnt even spin when I tightened the nut.
Total time working on it = 5 min. Total time researching it before trying to tap it out = 3 hrs. Hopefully, this will save someone else time and money. Those bolts arent very good if I can twist it off.
BSK
10-03-2007 09:30 PM
Brdman*
16
10-18-2006 01:50 PM
sTTay down
08-25-2006 02:31 PM
beejohn
06-05-2005 10:13 AM
beep-beep
Wheels & Tires Discussion
10-01-2003 02:54 PM
