Bubbling sound during inlet air pressure test?
(Cross Post from A6)
I have a code for low boost pressure so I made the Y-pipe test fixture per the AWE Tuning recommendation expecting to find a cracked TBB or air leak somewhere. I have the main inlet and the 3/4 PCV inlet capped off. With about 10psi static pressure I hear no air leakage, but I do hear liquid gently bubbling steadily that stops when the presuure is disconnected. There are no liquid leaks anywhere.
If I block PCV valve (disconnected from the 3/4 outlet on the Y-pipe) I can blow oil out the dip stick tube.
The only symptom apparent when driving is harsher shifts. Ideas anyone??
The_Jerbel (Jordan)
10-24-2006 09:11 PM
DWC_2.7T
03-27-2006 06:53 PM
daves4
03-19-2005 09:56 AM
S4zero8
03-15-2004 07:04 AM
expos
11-22-2003 10:42 AM
