Buddy's S4 keeps blowing fuse #34 and throwing it into limp mode. Checked engine ground wires
below the coolant tank and they were bolted tight to the firewall. Any ideas as to why the fuse keeps shorting out?
Here are the codes he has when the fuse is blown:
20 Faults Found:
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-00 - -
16538 - Oxygen (Lambda) Sensor B2 S1: No Activity
P0154 - 35-00 - -
16544 - Oxygen (Lambda) Sensor B2 S2: No Activity
P0160 - 35-00 - -
17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
P1114 - 35-00 - -
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-00 - -
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-00 - -
17938 - Camshaft Timing Adjustment: Short to Ground
P1530 - 35-00 - -
17955 - Boost Pressure Regulation Valve (N75): Short to Ground
P1547 - 35-00 - -
17697 - Boost Pressure Control Valve (N249): Short to Ground
P1289 - 35-00 - -
17530 - Oxygen (Lambda) Sensor Heating; B2 S2: Open Circuit
P1122 - 35-00 - -
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17526 - Oxygen (Lambda) Sensor Heating; B1 S2: Open Circuit
P1118 - 35-00 - -
17861 - Exhaust Gas Temp Sensor 1 (G235): Open or Short to Plus
P1453 - 35-00 - -
17865 - Exhaust Gas Temp Sensor 2 (G236): Open or Short to Plus
P1457 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
17523 - Oxygen (Lambda) Sensor Heating: B1 S1: Short to Ground
P1115 - 35-00 - -
17527 - Oxygen (Lambda) Sensor Heating Circuit: B2 S1: Short to Ground
P1119 - 35-00 - -
17548 - Oxygen (Lambda) Sensor; B2 S2: Internal Resistance too High
P1140 - 35-00 - -
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-00 - -
17947 - Clutch Pedal Switch (F36): Implausible Signal
P1539 - 35-00 - -
After replacing the fuse and clearing the codes, more than half go away and the car is no longer in limp mode. He has these codes with a working fuse:
8 Faults Found:
P1122 - 35-00 - -
P1118 - 35-10 - - - Intermittent
P1606 - 35-00 - -
P1114 - 35-00 - -
P1140 - 35-00 - -
P1453 - 35-00 - -
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
P1131 - 35-00 - -
20 Faults Found:
P0134 - 35-00 - -
P0154 - 35-00 - -
P0160 - 35-00 - -
P1114 - 35-00 - -
P1606 - 35-00 - -
P1425 - 35-00 - -
P1530 - 35-00 - -
P1547 - 35-00 - -
P1289 - 35-00 - -
P1122 - 35-00 - -
P1118 - 35-00 - -
P1453 - 35-00 - -
P1457 - 35-00 - -
P0102 - 35-00 - -
P1115 - 35-00 - -
P1119 - 35-00 - -
P1140 - 35-00 - -
P0140 - 35-00 - -
P1539 - 35-00 - -
8 Faults Found:
P1122 - 35-00 - -
P1606 - 35-00 - -
P1114 - 35-00 - -
P1140 - 35-00 - -
P1453 - 35-00 - -
P1131 - 35-00 - -
so i don't know if you can get to it without removing the bumper, you will have to remove the belly pan...
I know this place is a ghost town, but for archives sake. My problem was the passenger side cam tensioner solenoid. It was causing the short. Replace the solenoid by itself, not necessary to replace the whole cam tensioner. The solenoid is just 2 little screws, R&R in 15 minutes total. Good as new.
But you will have to find someone parting a car out, as the dealer and parts reps, will not seperate the solenoid from the cam tensioner.
xxBlitzkriegxx
08-31-2009 08:11 PM
AudiRacerA4
10-16-2008 09:44 PM
PKmode
09-26-2006 05:25 AM
PKmode
09-25-2006 10:53 AM
PKmode
09-21-2006 08:09 AM
