Bumping noise whilst driving
Hi,
I have a strange problem with my car. Thought I
would try and pick your brains before the
dealership (90GBP an hour here).
I have what can only be described as a bumping
noise when moving forwards, like what it would
sound like if you had something stuck in the tyre.
It seems to originate from the centre-front area
It starts at +20mph and the bumping increases in
frequency proportional to the vehicle speed.
Independent of engine speed or load.
Happens when the brakes are applied as well (i.e
it's not a warped disk)
Seems to get slighly louder on banked turns (left and right)
Occurs with the clutch in or out.
Occurs with the engine switched off.
So, I think it's somewhere in the transmission or
driveshafts&CVs ;-)
Any thoughts?
(I checked the tranny oil level and it was a little low but that's now been topped up and the
noise still persists)
Thanks,
Jon
driveshafts&CVs ;-)
Any thoughts?
Thanks,
Jon
<center><img src="http://wut2c.com/Video_clips/trunk%20monkey.jpg"></center><p>just messin' sorry...could be a number of things
But from the way you describe it...it sounds like the sort of thing that happens when you get snow on the inside of your wheels...but i doubt thats the case this time of year. Im assuming you already did a quick look over of all the components under the front of the car?
I didnt see it until I got it up on a lift. It was a good thing I found it when I did, because if it had burst, it would have been bad.......
later due to warranty lag. Could also be, any other rotating object on the car. It it a fast bump, slow bump, metal sound, rubber sound, loud, soft? Good Luck
sy233
05-15-2018 06:54 AM
