Calling BLK01S4 and other Stage 3 TIPs...some serious problems and I need some help
#14
Fueling is done. Inj, MAF and S/w need to go in at the same time.
Hunting at idle could be inj but likely is due to maf, fueling.
#15
Before I had the trans rebuilt I had the KO4's with the Revo same as now and kept it on low boost around 14-12psi boost curve. And that felt strong and was way faster than stage 2+ running higher boost.
Drove it again today and the results everytime were peak at 22-20psi then drop to around 10 or 12 then back to 17/18 and then everytime it'd go to 5psi which is obviously limp mode.
Fault Codes:
P1544
P1172
P0304 misfire cyl #4
Fault Codes:
P1544
P1172
#19
I can't give feedback on everything till the car is running ok but the trans feels extremely strong and the service they gave was also very good.
