Can anyone confirm for me that the T and M boxes are interchangeable? The dealer is apparently
having difficulty finding me an M box, but can get a T box without issue...the chip going into it was tuned on my M box so before I let them get me a T, I just wanted to make sure that I would still be okay...
TIA
TIA
However, if you are replacing the chip, then you can use any (at least any 6-speed, not sure about the tiptronics) ECU. When you replace the chip on an A-box ECU with one from an M-box ECU, the ECU becomes an M-box. The code on the chip is the only differentiating factor.
-Dave Pramanik
-Dave Pramanik
... so if you are attempting to swap other ECU combos w/o SW.
Don't forget about the ICluster having to match the software versions if you are swapping boxes/chips/sw.
