Can anyone enlighten as to sources for OEM brake rotors
that are lighter, multi-piece, better vented, replacements for the OEM rotor. BIRA.org talks about a Coleman rotor but NO ONE seems to be able to find where these exist. Does anyone know of better-performing OEM sized rotors that one can actually find and purchase?
theracestore.com... has slotted and drilled replacements
the drilled ones aren't actually drilled... they're cast with the holes which is the right way to do it. Unfortuantely, the internal venting of these are radial just like the factory rotors, not directionally vented like more expensive ones.
And they're only $350 for a front set, which is the cheapest brake upgrade you can make, other than pads.
Porsche 993tt rotor upgrade, under stock calipers!
I know your asking for stock rotors, which at the moment we don't have, but we are about 1-2 weeks away from completing our 993tt brake rotor upgrade. This will be a bolt in upgrade that uses 993tt rotors, custom mounting hat & fits under stock calipers & pads.
ECS Tuning hats are made from 7075 aircraft aluminum & of course the Porsche rotors are cross-drilled. Perhaps cross-drilled is the incorrect term, the Porsche rotors are cast with holes.
Also, our rotor upgrade kit will be fully upgradable, so all customer that have purchased our rotor upgrade will have the option of stepping up to our
stage III, which includes matching Porsche calipers, for minimal $$.
Tom
ECS Tuning
800/924-5172<ul><li><a href="http://www.ecstuning.com/">http://www.ecstuning.com/</a</li></ul>
Tom
ECS Tuning
Tom
ECS Tuning
800/924-5172
40+ years & counting of tuning the finest automobiles
in the world, namely V/W & Audi
Tom
ECS Tuning
800/924-5172
Carlo555
08-23-2008 04:02 PM
