Can I use a boost controller to raise my boost a small amount over the 14-15psi set by GIAC reflash?
I was wondeing if I could safely(read: Not extremely terrible for the car) raise the boost with eith a manual or electronic boost controller. I am stage 1 and have a GIAC flash that hits around 15 psi. Would it be ok for the car or even worth it to raise boost by a small amount, without changing anything else? Also I was think more along the lines of electronic so that I could just raise psi for short periods. What would be a safe psi to boost to? I run 93 octane.
fueling is based on load, which is based on MAF readings, which increase as the boost increases... as such so does the fueling.
Sure, there's a limit to the stock injectors, but they're not maxed out at 15psi.
He won't run lean at 17-18psi.
Is adding a 5 bar FPR easy and how much would it hurt gas mileage? With out a Wideband A/f gauge is there a safe way to tell if the car suddenly s running too lean?
ECU that already has raised boost AND adjust fuel timiing pleease send me a link. This is what I want to know. Does GIAC's adjustments allow for more boost safer, or is it no different than stock?
mosmoe (OPG)
21
12-31-2006 11:37 AM
A42.0rgy
Performance and Tuning
09-27-2004 10:32 PM
how much boost should i run w/ a greddy boost oh yeah i have stock ko3's but stage2 plus!!!!!!!!!!!!
~DonQPremiumTequila~
9
01-15-2004 02:51 PM
TTschwing
11
02-03-2003 10:09 AM
