Can Lemmiwinks be used to disable the vehicle?
Old 08-30-2006, 03:35 AM
  #11
AudiWorld Expert
Mirror|rorriM's Avatar
So with Lemmi, you can make it kinda-sorta-not-really run, but not disable ignition completely?
Old 08-30-2006, 04:38 AM
  #12
lemieux@curbside's Avatar
2 screwes on each side would work .. easy access to that is not the best thing either
Old 08-30-2006, 08:48 AM
  #13
Member
PSmalls::AnalRetentiveNumbNut's Avatar
Huh? I just assume you don't know if you don't spell it out.
Old 08-30-2006, 09:37 AM
  #14
Mike2kS4's Avatar
Default Basically...
There's nothing I'd recommend. But secondary affects injector gain, that, combined with pulling primary would make it not run at all.
Old 08-30-2006, 09:41 AM
  #15
Mike2kS4's Avatar
Default OK, since I'm feeling generous:
Ever think about recoding for a European cluster/ecu that requires an immobilizer?
Old 08-30-2006, 10:10 AM
  #16
Member
And how does that involve Lemmiwinks?
Old 08-30-2006, 10:25 AM
  #17
Mike2kS4's Avatar
:P
Old 08-30-2006, 10:28 AM
  #18
Member
Default ?
And are you sure even pulling 25% primary and setting secondary to 0% would result in the car not starting?
The real EF, please stand up!
Old 08-30-2006, 11:03 AM
  #19
Mike2kS4's Avatar
Default Yes, I'm 100% sure.
Actually all you need to do is go to 0% on secondary and the car will not run. It'll just crank with an occasional sputter. BUT it does dump a good amount of fuel in there so you should pull primary too.
I confirmed it last night on my Avant, but figured you'd try to do some independent learning :P
s-envy
Audi Original "S" Cars
05-05-2010 07:32 PM
Uhlinator
12-21-2007 09:51 AM
urS4isS2pid
10-13-2003 10:23 AM
got_root?
08-25-2001 02:11 PM
malangsTTer
10-07-2000 08:17 AM
Quick Reply: Can Lemmiwinks be used to disable the vehicle?
