Can someone explain this MBC setup?
They have a pressure regulator installed to prevent overshoot. I don't see how it would work.
<img src="http://www.mpperformance.com/catalog/images/SMBC.jpg"><ul><li><a href="http://www.mpperformance.com/catalog/product_info.php?cPath=29_30&products_id=44">h ttp://www.mpperformance.com/catalog/product_info.php?cPath=29_30&products_id=44</a></li></ul>
The pressure regulator is just functioning as an adjustable bleed for the wastegate line.
Most MBCs have a hole to bleed off pressure in the wastegate line so the the wastegate doesn't get held open once boost pressure drops below the MBC setpoint. The pressure regulator will only allow X psi to go to that line and vent the rest.
If we are using a parallel setup with the N75, the bleed (and pressure regulator) is unnecessary as the N75 bleed does the job for it.
-Dave Pramanik
-Dave Pramanik
Yep, you can make AVCR ramp however fast or slow you'd like...
<center><img src="http://pictureposter.audiworld.com/38083/cimg0951.jpg"></center><p>You should have little trouble tweaking the curve to placate any chip. Combined with a TCD, it's golden
jsbell_87
10-10-2008 04:15 PM
Im@wesome~ out!
40
11-30-2007 05:36 PM
Imolavirus@BuehnEngineering
13
09-17-2003 04:32 AM
Controlling boost......after reading the Autospeed DIY Audi boost control article, it doesn't make..
QGMika
Performance and Tuning
11
03-20-2003 09:18 PM
