Can someone help me with Throttle Adaption with the APR chip..
I can't seem to get the Throttle Adaptation to work.
Every time I try to activate it, there are no noises, or apparent clues that anything is happening..
Can someone give me a step by step guide, including when to do it, and after a drive, while engine is cold.. etc?
Thanks
Thanks
the adaption is complete . . You will hear throttle valves doing funky things if you listen closely. I think they are actually changing their appropriate degrees in correlation with the ecu protocal . .not sure correct me if I'm wrong . .=)
you have to do it with the engine cold (from what I've read). I think insturctions are on APRs website - www.goapr.com
Pelican Pete
A4 (B7 Platform) Discussion
05-16-2008 11:23 AM
Ring-Go
09-11-2002 12:56 PM
Polarbear
05-04-2002 02:15 PM
RuS4
10-12-2000 05:19 PM
