can someone post a log of timing (block 003) during warm idle? - preferably stage3
my mechanic thinks my tune is wicked wacky and the base timing map is causing misfires.
<img src="http://mysite.verizon.net/bagodoosh/S4_timing.gif">
he said the timing spikes to near 30 degrees is not normal.
logs please? comments?
from what i know, idle torque/rpm is maintained via varying timing.
i dont have logs handy, nor do i know what is "normal" though. ill try to dig through some of my old logs and see.
01.5, K04, custom tuned
i have the hitachi MAF, so the assumption was that its failure would be more unlikely. the graph i posted does have MAF data. the mechanic did not notice anything abnormal.
before i drop any names, i'd like to see some data of what the timing should look like at idle.
my mechanic was also concerned with the high degree of fuel/lamda correction, so he had more reason to doubt the tune:
<img src="http://mysite.verizon.net/bagodoosh/S4_fuel.gif">
FYI...your car was missing prior to the tune being installed. We discussed this......
and you agreed.
I would start with the basics. If your shop isnt able to figure it out, I would be more then happy to figure out what mechanical issue is causing misfiring.....
Let us know how we can help!
