Can someone stop the leak in this car B4 i F$king junk this thing!!!
the rear floor passenger side was soaked when it rained..can is be my rear window seals>>?? only the floor was wet....its killin me
did you recentely install a stereo or boost gauge, etc?
Either way check all the rubber grommets near the firewall in the engine bay. I had the same problem and i found there was a leak because of a speaker wire i was running near the ECU box, the grommet didnt seal properly after running the wire through it. The water would run down my dead pedal, along the side of the floor and pool up on the driver side rear seat. Many hours later i had to rip up some carpet and put a heating lamp in there to soak it all up. Hope this helps.
Pull off your door panels and check to make sure the
"rain coats" Ie, the foam liner things are intact and in place.
Next thing is to check the bottoms of the doors to make sure the drains there aren't blocked.
Then check the sunroof drains...
EuroVWGTi
26
06-19-2008 05:32 PM
DanMc
14
01-02-2005 01:23 PM
jarussell
03-11-2003 04:57 PM
