car boosts only 5 psi and throttle cuts off
codes are:
9 Faults Found:
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-00 - -
17938 - Camshaft Timing Adjustment: Short to Ground
P1530 - 35-00 - -
17955 - Boost Pressure Regulation Valve (N75): Short to Ground
P1547 - 35-00 - -
17697 - Boost Pressure Control Valve (N249): Short to Ground
P1289 - 35-00 - -
17529 - Oxygen (Lambda) Sensor Heating Circuit: B2 S2: Short to Ground
P1121 - 35-00 - -
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
17861 - Exhaust Gas Temp Sensor 1 (G235): Open or Short to Plus
P1453 - 35-00 - -
17865 - Exhaust Gas Temp Sensor 2 (G236): Open or Short to Plus
P1457 - 35-00 - -
No boost leak code.
O2 were replaced 5K miles ago.
Please help.
9 Faults Found:
P1425 - 35-00 - -
P1530 - 35-00 - -
P1547 - 35-00 - -
P1289 - 35-00 - -
P1121 - 35-00 - -
P1117 - 35-00 - -
P0102 - 35-00 - -
P1453 - 35-00 - -
P1457 - 35-00 - -
No boost leak code.
Please help.
Thanks to eveybody for help, I also did search forum for similar codes and
- 2 vacuum hoses clams were very loose;
- Fuse# 34 (ECU) was blown;
Fixed all these and now back to 20psi and no codes so far....
PKmode
09-26-2006 05:25 AM
PKmode
09-25-2006 10:53 AM
PKmode
09-21-2006 08:09 AM
BLK01S4
15
08-02-2005 07:44 PM
sissupr
05-20-2003 08:26 AM
