Car dies but does start back up. ABS/ESP lights are on now. Any input?
I'm afraid to drive anywhere and get stranded.
My ECU has had problems with the board from a hack solder job (bought it as a GIAC chipped ECU second hand). Mark @ ASP cleaned it up as well as he could last summer but I think one of the "pads" on the circuit board has a problem.
Anyone else ever have these codes? Was it the ECU? ignore the misfires...
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 8D0 907 551 M
Component: 2.7l V6/5VT G 0001
Coding: 06711
Shop #: WSC 12345
6 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16685 - Cylinder 1 Misfire Detected
P0301 - 35-10 - - - Intermittent
16690 - Cylinder 6 Misfire Detected
P0306 - 35-10 - - - Intermittent
16686 - Cylinder 2 Misfire Detected
P0302 - 35-10 - - - Intermittent
16688 - Cylinder 4 Misfire Detected
P0304 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04395
Shop #: WSC 06435
1 Fault Found:
18258 - Powertrain Data Bus: Missing Message from ECU
P1850 - 35-10 - - - Intermittent
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Coding: 00160
Shop #: WSC 63351
No fault code found.
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 920 981 B
Component: B5-KOMBIINSTR. VDO D12
Coding: 02264
Shop #: WSC 63351
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 16140
Shop #: WSC 63351
5 Faults Found:
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 63351
Address 55 -------------------------------------------------------
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 63351
Address 56 -------------------------------------------------------
Controller: 8D0 035 195 A
Component: Radio D00
Coding: 00110
Shop #: WSC 63351
End -------------------------------------------------------
Coding: 06711
Shop #: WSC 12345
6 Faults Found:
Coding: 04395
Shop #: WSC 06435
1 Fault Found:
Coding: 00160
Shop #: WSC 63351
Coding: 02264
Shop #: WSC 63351
1 Fault Found:
Coding: 16140
Shop #: WSC 63351
5 Faults Found:
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
00956 - Key 2
Coding: 00101
Shop #: WSC 63351
Coding: 00012
Shop #: WSC 63351
Coding: 00110
Shop #: WSC 63351
eisman.s4
05-15-2006 09:29 AM
madchemistnj
01-30-2006 06:07 AM
TTagz
08-05-2005 08:20 AM
Rally_nutcase_1982
Audi allroad
07-30-2003 06:32 PM
