CEL came on, buddy VAGGED the S, came back w/ the following code (inside) little help needed
16805 - Warm Up Catalyst; Bank 1: Efficiency Below Threshold
Assuming it is a o2 sensor....maybe? if so, which one? Any other ideas. Friend mentioned mt cat my be going by quickly dismissed that as my car only has 57K on it. TIA!
i take back what i said originally. if your o2 sensors are original, you should go ahead and replace your front o2 as preventative maintenance and to possibly remedy this code
Bank 1 is drivers side correct. Also, is the sensor located in the DP so I gotta pull the DP and replace it??
conclusion the cat has to be replaced, loose parts inside, it's defective. My cat back system is AWE, 2yrs ago bank1 cat was replaced (free of charge) by AWE, this cat was part of a bad batch they produced in 2002. Now it's the bank1 cat, probably the same thing, my car has only 27K, I'm waiting to hear from AWE.
sutherland
01-28-2009 12:50 PM
audi2.7audi
05-03-2007 06:31 PM
