CEL on, N75 error.
Hi,
Been a while since I've posted. Been busy with work / other cars...
Driving the car home from work, CEL came on. When I arrived home I hooked up vag-com and saw the errors below.
17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
17956 - Boost Pressure Regulation Valve (N75): Open Circuit
P1548 - 35-10 - - - Intermittent
I went ahead and order a universal 4-wire from ECS, and an N75 valve. However, I'm having second thoughts about the N75. Any chance that it's not the valve, and just a host leak?
Anybody?
Thanks,
Tom
Anybody?
Thanks,
Tom
N75 doesn't look like a hard fault and will not turn on the CEL anyway. The O2S turned it on, replace that, clear codes, and wait to see if the N75 code comes up again; but it was intermittent so it may not.
Come on mike@streamline, diagnose then replace. Didn't I teach you anything
Thanks. Didn't know if N75 would throw CEL or not.
I cleared codes last night. I'll replace the 02 sensor first just to try and nail it down. I didn't try diconnecting the N75 with ignition on, I will try that. It'd make sense that it would throw an open circuit code if I did disconnect.
B2 S1 sensor is driver's side front, correct? Not really looking forward to it, I haven't had to do anything except change fluids / brakes / rotors for quite some time.
Since you're reading this - are all 4 O2 wide band, or just the front? (just curious)
drivers side front and it is the more difficult one. None of B5S4 O2 sensors are wideband.
Parts just arrived, I just have to get the 2002 out of the garage so I can do this.
You sure the pre-cat aren't wideband? Seems like Audi wouldn't be able to tune well for varied barometric levels/fuel quality without wideband.
Also, I was just comparing comparing to the Bosch WB02 used in an Innovate LC-1. Looked like the same thing.
The sensor housings may look similar but the WB wiring should have an extra red or yellow wire? Good luck!
HACK THS
08-21-2008 05:53 PM
Kingttr
04-19-2007 09:27 AM
Mike@StartupRacing
07-21-2006 06:11 PM
Replaced N75 valve and still go into limp mode pulling on low rpm's. What gives? Wat else could it b
twoquattros
07-29-2005 05:30 PM
