Clunking from rear suspension?????
I installed FK Konigsports a while ago and since then when I go over small bumps, and bumps in general there is a clunking, hammering noise from the rear suspension....
Has anyone encountered this problem before???
And when there is someone in the back seat the noise is less????
Any help would be helpful......
Thanks
Thanks
Former Vendor
Sounds like the spring isn't tight between the perch, and as a result it's getting loose and making noise when you hit a bump.
Try raising the ride height slightly.
I double checked everything and nothing related to the suspension install is loose. It sounds like a clunking/rattle coming only from the driver side rear and I only hear it on bad roads going slow. Once I get on the freeway I don't hear it at all, maybe the same problem? Someone mentioned it might be my sway bar mounts, can't find anything wrong with that and I've tried raising the height of my car with no luck. Do you have an aftermarket swaybar?
Stock sway bar.....no idea
What is your MSN IM, if you have one???
