Which clutch to get???
I can feel that my clutch is slipping, and not sure which clutch to go with.... I see alot of people recommend the spec stage 2, but I am Stage 2, and prob wont go stage 3 for some time. Also this will be mostly street driving, with an occasional 1/4mile. Any advise?
thx
thx
Which IIRC is something like the RS4 pressureplate and stock clutch..although I've heard of something from vast which is just as cheap but better (the clutch I mean...still uses the RS4 pressureplate).
I run the RS4 clutch (which is RS4 pressure plate and stock clutch) and I'm stage2+ and do the same as you
maybe bigger than KO4's,will that clutch hold??? Or is there a clutch that is able to hold more power, but still ok with the Stage 2?
....there are stage 3,4,5 and i think even a 6 made by spec. i dont know the highest for this platform but i know they make em up there for other applications. be warned of pedal feel though of a SPEC clutch over stage 2 (stg 3 on up). you will not like it for daily driving more than likely. especially if you seldomly take it to the track. i'd say if your serious about building this thing over 500hp then go stronger than RS4 but under that should be good.
