clutchmasters stage 3 capacity
im stage 2+ but plan on going stage 3++ around 450whp maybe more.. will the clutchmasters stage 3 be able to handle this? what capacity is it rated for? yes i stfa.. any help would be much appreciated bc i need to get a new clutch in like.. NOW
driving? CM stg 3
i have CM stg 3 & k04/rs6 w/ ASP fueling. no issues so far . . . <knocks on wood>
i'm too lazy to look it up, but Stg 3 they say is 110% higher than stock and Stg 4 is 170% higher than stock. that might be a general figure for all their Stg 3/Stg 4 clutches, though <shrugs>
how much power r u making? i plan on takin it to the strip a few times and launchin it on the street hard a bunch of times.. hard decision bc i already have a fidanza aluminum flywheel sitting in my garage and i know u cant use that with stage 4. but if the the clutchmasters stage 3 can only handle like 460whp its prob not worth the risk.. i want to make as much power as i can on k04 without touching the internals.. was thinkin 2.8 heads, asp manifolds, homebrew fueling, and epl tune.. is this setup gonna be too close to the 500whp mark? (time to beef up rods and valvetrain) would love to hear any feedback! thanks!
CM Stg 3. i thought the Fidanza worked or that it could be modded to work with the CM clutches.
for that level of hp. A full feramic surface disperses heat better and the engagement is near stock like. After the SPEC quickly fried in my setup, we replaced it with this option and have not had an issues to date. Now...if your feeling more ambitious about your intended hp level you could consider a twin disc setup that ASP just developed.
Roque
33
06-18-2008 08:55 PM
Searched and still no definite answers. Will the CM stage 3 clutch be enough for my ASP stage 3 car?
Jesster
35
04-07-2007 10:49 AM
Neon01
95
03-05-2004 03:18 PM
fka smurfette
12
07-25-2002 10:29 AM
