Codes help please: limpmode
Please help. I have 2000 S4 with 93oct APR chip & 710n's, the rest stock.
While on full throttle I get hesitation and sometimes misfires. I got it smoke tested and had the following codes below.
The smoke test found a small leak in the breather hose/tube near the passenger-side bypass valve, as well a leak in the 5th cylinder fuel injector seal.
17865-Exhaust gas temp sensor 2 (G236) Open or short to positive. P1457
16684 Random Multiple cylinder misfire
(also misfire code on all cylinders)
17539 Oxygen sensor B2 S1; Internal resistance too high
17869 Exhaust Gas temp regulator for bank 1; Implausible Signal
Does anyone think that if I get the seals replaced for the fuel injector as well as replace the leaky breather hose, that it may solve the other problems?
Or are my EGT's for sure bad? If so, are BOTH bad?
Thank you very much for any help.
EGT 1 has failed or is failing, either way your EGTs are both ****ed. Which will cause limp at WOT.
Yeah, doing the O2 at the same time wont really save you any time unless your going to drop the down pipe or something.
About the leak. pretty much any leak on these cars should get fixxed since it will cause a lean condition and the car will just dump more fuel.
jimzigg2
03-17-2008 04:50 PM
