coil-overs
coil-overs
I am now 3/4 of the way done installing my coil-overs. I have the rears done(was easy)and its just fine tuning the ride height. Now with the fronts, I got the assy out and just had a question and hopefully its not to dumb. Do I need to compress the springs to take off the top to switch everything over? And also, will I have to compress the H/R springs to reinstall? One more thing, from the ground to the bottom of the fender(centered), what ride height do most people suggest? Keep in mind I live in Minnesota. Thanks for any info.
Yes! Use spring compressors.
You risk injury if you don't.
As for the ride height, my H&Rs are set at 25.25". This is probably too low for you if you plan on keeping your height set the same through a MN winter. Perhaps 25.75"?
quattro_silver
07-11-2008 11:41 AM
S4_NE
17
05-20-2008 06:48 AM
Geoffrey G
04-22-2001 09:34 PM
