Cold start question
I STFAd and did not find anything definitive. I replaced the OEM battery in September with a Sears DieHard International. This evening after work I went to start the car and it cranked twice then went to turn over but started cranking again so I went to let go of the key and the car turned over...but weakly. The car sat in the lot for 8 hours in about 25 degree temps so it was butt cold. I had this problem a couple weeks ago but the car was about 25% warmed up. Both times the car started but did not start up as usual.
So I know it is not the battery, I've seen people mention the coolant temp sensor, any other suggestions/ideas?
Hard to say what is exactly happening here but you may want to also have a shop check out your ignition switch. The electrical portion of the switch is plastic and wears out. Just a thought.
Good Luck
Good Luck
jloktalGst
05-30-2018 03:56 PM
Brady Miklos
10-03-2016 06:52 PM
