Coolant Leak Found
Hi All,
I found this coolant leak (see link below). It took quite a bit of digging around but found it underneath the after run coolant pump. I will be replacing the seals to all 3 black pipes you see in the pic. Is there anything else I should check or do while I have the intake manifold off?
thanks.<ul><li><a href="http://picasaweb.google.com/albertedavison/DavidBeckhamGame/photo#5150992644205664482">http://picasaweb.google.com/albertedavison/DavidBeckhamGame/photo#5150992644205664482</a</li></ul>
I dont think so. I would smell coolant pretty much anytime the car was warmed up. I think this was b/c there was always a little "puddle" of coolant as seen in the pic. Then it would overflow and I would get a small leak every once in a while.
Is the after run coolant pump the same thing as the auxiliary water pump?
thanks.
thanks.
JordanS4
08-03-2006 06:37 AM
LosGatosS4
16
10-10-2003 12:56 PM
Kirath ¾-B0§t0n
10-30-2002 12:06 PM
