coolent temperature sensor o-ring question
Just replaced the passenger side EGT so I decided to replace the coolent temp sensor while I was in there. When I got the CTS out I noticed that there was NO o-ring but I thought maybe I just dropped it when I was pulling the sensor out. Went to put the new sensor and o-ring in and there is no frickin way that thing would fit with the o-ring on it so I put it in without the O-ring and it fit nice and snug. Buttoned everything back up and will give it litte drive to see if I have any leaks but I was just wondering if anyone else has had troubles with the o-ring and left it off???
Thanks
Thanks
I'm asking because I got an EGT error code (see my post below from about an hour ago) and I don't know how to figure out if it's the driver's side or passenger side that's causing the CEL. What's the difference between the EGTs?
if you want to be sure, pull the sensor back out, and stick your finger in the tube to see if you can find the o-ring that way... they do get kinds old and crusty. i replaced mine with the sensor when my g62 went bad.
cbons
Audi allroad
05-01-2007 01:12 PM
