Could a broken/damaged ECT cause bad gas mileage?...
Old 02-14-2006, 03:59 AM
4Bidden's Avatar
Default Could a broken/damaged ECT cause bad gas mileage?...
I've only been getting about 200 mi before the light comes on and I don't push my car too hard, not always that is.
Old 02-14-2006, 04:49 AM
Audiworld Sponsor
DAP@EPL's Avatar
Default Yes. A bad EGT sensor could as well.
But the coolant temp sensor is MUCH cheaper and easier to replace so try that first.
-Dave Pramanik
Old 02-14-2006, 04:56 AM
4Bidden's Avatar
Default The only codes i'm getting are:
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
I am not getting any EGT fault codes.
Old 02-14-2006, 05:03 AM
Elder Member
Rican_S4's Avatar
Same code mine threw when my CTS went out. I also had bad gas mileage. Very cheap and easy fix.
Old 02-14-2006, 05:57 AM
4Bidden's Avatar
How is your gas mileage now that its fixed?
Old 02-14-2006, 05:58 AM
4Bidden's Avatar
Old 02-14-2006, 06:00 AM
StoneMan's Avatar
Well, I've got the same code, and I'm starting to get poor gas mileage. So, I'd say yes
Old 02-14-2006, 06:48 AM
Elder Member
Rican_S4's Avatar
Default Considering I hit a deer a short while after & the car has been sitting while I get my Stg3
parts together I'd say the mileage is EXCELLENT! jk jk
All jokes aside I would say that my gas mileage did improve by at least 10mpg after the CTS change but mine was terrible when I changed it.
Old 02-14-2006, 06:50 AM
RKA
AudiWorld Uber User
RKA's Avatar
Default It's a $5-10 part.
O2 sensors, and EGT sensors could also be suspect, but they are a LOT more than the CTS, and harder to replace.
Replace the CTS first...if that doesn't fix the issue, then worry about what's next.
Old 02-14-2006, 09:08 AM
4Bidden's Avatar
I am getting 200 mi per tank...I would consider that terrible.
Quick Reply: Could a broken/damaged ECT cause bad gas mileage?...
