Is cutting Fuel Pressure Regulator line for boost gauge vacuum line a bad idea?
#15
In reality, how many times have we heard about someone F'ing their engine up as a result of a boost guage leak? I don't recall even one.
#16
why not have a leak in a place where the risk of damage as a result is minimal or zero as opposed to probable or likely?
Sorta like if someone said to you...you're going to have to bleed...would you rather bleed from an artery or a vein? External or internal? Then the choice is easy...vein please external. The decision on the FPR tap for the Boost gauge should be this easy...it's obvious it's not a great place as it could have consequences...certainly more so than those associated with other tap locations.
#17
you see nothing on the dash, time to shut off the car and check for leaks, as opposed to not knowing your fuel pressure's dropped from an undetected leak and you can kiss engine bye bye. Kinda like a win-win situation.
#18
We could come up with 100 different scenarios where different mods result in adverse affects and ways to minimize them. I don't feel that there is a great enough risk of generating a leak where I mounted my boost guage to necessitate routing the tap further away just for added security. Obviously you feel differently. My tap is secured as well as any of the other hose connections in my engine bay. I don't lose any sleep over it.
#19
if there is a leak in this critical area. One might argue that point by saying, well what are the odds of the stock FPR hose/clamps ever having a leak, and I would argue the same for the gauge T when installed properly. *shrug*
#20
as possible. The less hose you have the less there is to inspect...the less likely it is to get damaged by moving parts or rubbing against things. I've replaced that hose with a Silicone hose myself as the OEM one is prone to rotting...the hose that comes from the factory is basically trash IMHO...it dry rots inside of a year :-/
Regards,
Regards,
