CV axle grease. - Experts?
is MolyB Die Sulfide required, or only if its NLGI Grade 2. Like other Moly Greases. The mobil 1 is red, but i think all moly containing greases are a metalic black / grey.
Is the mobil 1 fine? It has the same grade requirements, and is a lithium based grease.
Or just use a moly lithium based grease.
best easily found stuff is the Valvoline synpower for $5 a tube.
Look at the specs between the two and you'll see why.
You'll also notice that M1 doesn't say that its recommended for cvs . . . M1 has a problem with too much bleeding out.
Dave
Dave
<center><img src="http://www.pratthobbies.com/prodimages/krytox.jpg"></center><p>
From Rocketry catalog:
KRYTOX grease is specified for most hybrid motors, for lubricating o-rings and any components that come in contact with the oxidizer. Will not react with liquid nitrous oxide. 2 ounce (56.6 gram) tube. $36.95
Rolf
04-08-2007 05:07 PM
Shep 1.8T
05-17-2004 04:08 PM
