Cylinder 4 Misfires... not spark plugs or ignition coils... what is it?
#12
Update: I replaced the POS (Power Output Stage) from PureEMS...no more miss, no more codes.
The Beru replacement is not an exact dimensional duplicate of the OE Bosch, and it was interfering with the other one. I had to use a hand file to trim the base of it and the OE one slightly to make them fit. Do it slowly, fit and re-fit. Last thing you want to do is cut too much! But, once fitted, it works perfectly (yes, I tested it BEFORE I modified it, though being an electrical part it was likely not refundable anyway...)
And, for reference, if you're getting code PO304 cylinder 4 misfire, then replace the one with the brown connectors; if you're getting code PO301 cylinder 1 misfire, then replace the one with the black connectors. And make sure you use the goop it comes with and clean off the base well so it gets a good tight fit to the airbox; that's what keeps it from overheating (just like the fan base on a PC CPU).
Cheers!
Cheers!
#13
Cheers!
Cheers!
#15
check the ground wires coming off harness on rear of motor. coil packs have 2 grounds and built in modules, bad ground will cause a bevy of issues intermittent to permanent, they are in a crappy spot, i rewired them all to the same spot on the firewall as the left hand side of motor
#16
I have the exact same issue, p0300 and both cyl 3&4 misfire, would the ecs kit to delete both icm work, or should I consider just getting new icms?
tricky1090
9
05-05-2011 02:29 PM
Holographic77
13
06-30-2006 09:36 AM
M3KILR
11-18-2003 07:52 PM
Moneytree26
01-01-2003 04:09 PM
