Cylinder 5 misfires continuously at idle...
No misfire DTCs, but block 16 cylinder 5 counter increments about once every 5 seconds at idle with AC off, once per second with AC on.
I swapped coils and power output stages. Haven't looked at the spark plug yet.
Some messages here imply this is normal, but cylinders 1-4 and 6 never show anything other than 0, so it seems like cylinder 5 is "different", unless the detection algoritm is inclined towards false positives on cylinder 5.
causes from Bentley
Spark plug faulty
Spark plug connector faulty
Ignition coil or power output stage faulty
Fuel injector faulty
Check compression of one or more cylinder weak
how many miles do you have on the plugs?
Spark plug faulty
pending - Spark plug faulty
checked - Spark plug connector faulty
checked - Ignition coil or power output stage faulty
pending - Fuel injector faulty
pending - Check compression of one or more cylinder weak
16,000 - how many miles do you have on the plugs?
Does it actually "snap" onto the top of the plug?
BTW: What size socket does the spark plug use?
bwells1200
03-03-2012 09:42 AM
Update on no spark, I have got Kellys coil pack installed, i started the car and the #1 cylidner was
sk88erguy
Audi Original "S" Cars
13
08-27-2008 05:37 AM
QuattroA418T
09-28-2005 09:03 AM
Moneytree26
01-01-2003 04:09 PM
