Dead battery. Any instructions for replacing it?
Old 08-24-2006, 04:57 AM
Senior Member
biturbowagon's Avatar
Default Dead battery. Any instructions for replacing it?
Friend's '01 S4 Avant's battery is DOA. I'm about to go to Autozone to pick up a replacement, then help with install.
I STFA and found useful info (such as approbation for Autozone battery), but didn't find a tech article for the technically challenged. Can anyone point me to one if I missed it? It looks like it's more involved than just unbolting a bracket and lifting the battery out of the car.
TIA.
Old 08-24-2006, 04:59 AM
dscottjr's Avatar
Default Sounds like you've got it. If you're not a strong or tall fellow, there have been posts about how
difficult the battery is to get out
Old 08-24-2006, 05:01 AM
AudiWorld Expert
Captain Matt, I be's Avatar
i had some trouble with mine :/
Old 08-24-2006, 05:02 AM
dscottjr's Avatar
:-x
Old 08-24-2006, 05:05 AM
übertek's Avatar
no reason they had to put it dead center in the back of the engine bay, not your fault
Old 08-24-2006, 05:08 AM
lemieux@curbside's Avatar
Default there is a trick .. the gr48 from autozone will be a shorter battery so the bracket
on the pass side front corner holding the battery will not work the way it is anymore.
i mangeled mine and placed it in one of the bolt holes that will be revieled if you push the bat. all the way toward the driver side.. it's all about being creative
1) remove the plastic cover with the rubber seals( weather stripping), remove 1 screw holding the polen filter cover (pass side -7 or 8 mm)
2) turn the plastic phillips screws (levers) holding the plastic piece under the wiper.
3)unbolt the 10mm screws holding the + and - wires on the terminals and the 13mm bracket holding the bat down (pass side corner)
4)lift that cover so you can have room to take the bat out.. take the bat out .. put the new one it, push it to the right as far as it goes (so it catches the edge on dr side) ..bent, break the little bracket so it will fit in the new spot (need 2 pliers) .
like this:
<img src="http://pictureposter.audiworld.com/3015/104_0469.jpg">
Old 08-24-2006, 05:41 AM
Fixn2xlr8's Avatar
Default You can also hook up a trickle charger to the car while you are swapping. It will
keep you from having to reprogram the radio.
Old 08-24-2006, 05:45 AM
'Nova more S4's Avatar
Default Newp. don't need one. Just make sure the new battery is charged. Do it quickly and you won't need
the radio codes or reprogram anything, except the date / time on the cluster.
Old 08-24-2006, 05:47 AM
dscottjr's Avatar
They were trying to optimize weight distribution
Old 08-24-2006, 05:49 AM
Default There's a tech article that gives some tips such as which terminal to remove first and some pics
also disconnect the drain from the battery side so you can see where it is hangs down to.<ul><li><a href="https://www.audiworld.com/tech/elec129.shtml">https://www.audiworld.com/tech/elec129.shtml</a</li></ul>
Quick Reply: Dead battery. Any instructions for replacing it?
