DEFI HUD boost & timer failure.
ok, finally got done with all the electrical ordeal.
bottome line. my Defi HUD boost&timer was bleeding power back to the red wire that you suppose to connect to the power.
long line. i tested and found the plug with 3 wires off the timer unit (blue/green/red) and while the green is connected to the igition, the red was bleeding out power enough to light a 12v bulb.
hence it almost killed my battery/alternator, killed my fule pump kill switch(not sure how since evidence was destroyed by the dealer). after disconnecting the timer everything is functioning normally. I DON'T NEED NO STINKING TIMER, SYNTHETIC OIL IS ALL I USE!<ul><li><a href="https://forums.audiworld.com/s4/msgs/1023373.phtml">link</a></li></ul>
Armchair Pistolero
03-01-2004 09:09 AM
AndrewM (azdaspeed3)
01-07-2001 06:30 PM
Kim @ MotorKlasse.com
10-24-2000 07:01 PM
