Diagnosis: bad wastegate Solution: replace turbos...how I wish I had $ for K04's...
You never think it would happen to you, then it does...I'm so sad. Dealer called and said at least one of the noises was a bad wastegate on the turbo and was going to order the replacement of both.
Anyways, it'll be a couple of weeks before the turbos get shipped in, so I get to drive it around in a handicapped state until then.
Any suggestions of things I should consider having done? My extra cash flow is almost all spent after Christmas, so unless the dealer will comp the price of new K03's I don't think new turbos are an option. I don't suppose anyone had turbos replaced under warranty, but had the dealer install K04's instead, paying for only the price difference?
Anything else that can be done easily in conjunction with a turbo replacement? DP's, Bipipe, hoses? Do they pull the motor out to get to the turbos, or get at it from the bottom? If the pull the motor, I would definitely consider RS4 pressure plate/clutch if most of the labor is free.<ul><li><a href="https://forums.audiworld.com/s4/msgs/632384.phtml">Original Post</a></li></ul>
I think more and more people would actually have a look of excitement (as opposed to horror) after hearing that their turbos were blown. Hmm. I woul dbe willing to pay the difference. =-)
"Here it is, lancep AT metronational DOT com. Please email me shortly with what you had to say."
That is the "official" replacement method.
Some folks down in TX said that they have a local Audi tech at one of the dealers who has replaced the turbos without pulling the engine, but I don't think you can expect that to happen at every dealer.
