Did a few runs yesterday with my homebrew stage 3 setup. Anyone care to comment on readings?
#23
Timing: second and third gears:
Not sure if this is the correct group, but it was taken from logging Block 003, same log as the MAF log.
<img src="http://pictureposter.audiworld.com/40679/log-01-026-027-003_21200_image001.jpg">
#27
AudiWorld Expert
In general, you're best off doing a single pull in 3rd gear from 3000ish RPMs to ~Redline
That's what most are used to looking at, as well as it gives a nice broad range to see how values are sustained across the pull, not just during spikes, etc.
#29
AudiWorld Expert
I've noticed the same Re: high correction and low knock...
I've notice a few times that knock has been low and retard has been high. It almost seems like it's not "high knock causing high retard". But rather high retard results in lower knock.
yes, it's backwards from common thought, but I've definitely noticed it. The question also becomes then what drives cylinder correction if it's not driven by knock?
Anyway, I just wanted to go on record saying I've observed that before.
#30
Thanks. I am fairly new to logging, but logically, the high CF/ Low Knock V is kinda odd.
As soon as I put my new plugs in, I will make sure to do some logs, in third gear only. I will also do some FATS times. Thanks again!
