Did some VAG-COM mass airflow testing tonight, with and without MAF screen, etc... (long)
#23
the engine output wil be less, and the speed of the turbos will be reduced as well, because less air going in, means less air going out.( in theory). I don't see how they can overspin, when a large restriction can cause the turbos to actually pull a vacuum if the intake is blocked.
#24
.... operates partially open. So, the first reaction to inlet restriction would be the waste gate closing more, allowing more of the restricted throughput of the engine to go to the turbo. And, all along the ECU senses WOT.
#27
I'll have to check but I thought I saw as high as 180% load, but my flow rate never got quite that high. Now what variables go into the load calculation exactly? Also it was 80 degrees out, I suppose my flow rates might be higher in some cooler 40-50 degree weather.
back2black
08-24-2004 06:04 AM
Qiish
19
07-05-2004 12:12 PM
PSmalls::DoggieStyle
11
06-07-2004 06:58 AM
