diverter valves issue
my 2000 s4 has 129,000 miles on it i already have a borla exhaust thats the only mod. now i was thinking about a chip but a friend told me i have to change my diverter valves before i chip the car ... the problem im having is that i seen alot of diverter vaves online but i dont know wich ones are good for my car what do you guys recommend me??
Many people opt for the expensive billet valves. Personally I would rather spend the money elsewhere, but that is a personal choice that everyone makes. If you go with the 710N as suggested earlier you will be all set. That was also the way I decided to go and saved myself $200. Car's been running them for about 3 years now with no issues whatsoever. Incase you are interested in testing your existing valves here is an easy DIY: http://www.vaglinks.com/Docs/Misc/VA...rter_Valve.pdf
You don't really need to upgrade your stockers, but I would suggest keeping an eye on them if you chip it without replacing them. They will probably go a little sooner. FYI, the 710N does have a stiffer spring so it doea give you a little more boost before it opens, so there is a slight benefit to using them besides the reliability issue.
There is a ton of info on the links on the second page of the DIY if you want to know the benefits etc.
Cheers
Massboykie
I'm running the bailey DV's for about 15k. No problems so far. These are piston type, as opposed to the 710n, which is a diaphragm type. Most people run the 710n on their S4.
4Bidden
33
02-03-2006 02:28 PM
KNaudiA4
03-27-2003 07:52 PM
KEVS4
08-03-2002 09:04 PM
