Do I detect a slight negative camber dialed into the front suspension?
Guest
Posts: n/a
Not to single you out, but I've noticed that many of your "no text" posts do not include the "(nt)" at the end of the title. Perhaps you are accidentally entering spaces in the message box when you post, such that the automatic "(nt)" function is not working properly for you. Just a thought...
Guest
Posts: n/a
My stock S4 had about -0.8 or -0.9 degrees of camber in the front and -0.6 degrees in the rear. After lowering with the Vortrag Coilovers and a realignment, I've chosen to go with -1.3 degrees in the front and -1.0 degrees in the rear.
Corey S
'00 S4
Corey S
'00 S4
