Do I need anything special to change brake pads?
I know that for the rear I will need some kind of a tool to put the pads back in. As to the fron, Bentley mentions some hex scres that I am supposed to have new. Anyone know how to get these?
I have new pads, and normal toon (inlcuding rear brake tool). Do I need anythig else?
Tomasz
Tomasz
1. Break wheel lugs.
2. Jack up car and support with jackstand.
3. Remove wheel.
4. Unclip spring clasp on top of the caliper with a pair of pliers. (I've found chanel locks to be very helpful here)
5. If they are your original stock pads stick a flat head screwdriver between the backing plate and the caliper to break the adhesive.
6. Unclip brake pad sensor harness, you a small flat head screwdriver to unclip it.
7. Pull out pads.
8. Reverse the above process with the new pads on.
3. Remove wheel.
7. Pull out pads.
breaker bar to the mix. The jaws of life that firemen use to extract people from wrecked cars might help too. ;-)
DutchDoofus
9
09-05-2008 11:28 AM
kazino21
Audi A3 / S3 / RS 3
06-25-2003 05:59 AM
Ghant TMK
03-16-2003 06:07 PM
GTEJR
11-14-2002 04:56 PM
