Do we have bulb(s) that illuminate the rear license plate?
<center><img src="http://pictureposter.audiworld.com/6944/picture_002.jpg"></center><p>I think mine are out and hence I get this indicator.
What was strange last night was that the indicator would come and go at random for a few minutes. I don't know if this is some problem with the electronics.
Can someone explain? Should I just replace the bulb(s)? I don't even know what to get. Has anyone done this.
probably the reason it was going on and off
was a loose filament in the bulb casuing intermittent contact...which if wired in series would cause an open circuit, thena closed circuit etc....blah blah blah..
as for brighter replacements...some guy named junker on here used 2 raybrig R133's. they are about 10 bucks a pop. I assume you could just a buy a standard replacement at an autoparts store for much cheaper. i believe 133 is the type of bulb and that other bulbs that fit would have teh same designation...not sure though...
