Do we have a single coilpack that power all plugs or 6 coilpacks one for each plug?
From VAG reading, I'm experiencing several (0-6) misfires every 30 secs on different cylinders. Does it should like a Coilpack issue? Thanks
carbon deposits. Run a couple bottles of FI cleaner over the next couple of tankfulls of fuel. 6 every 30secs seems pretty normal for the 2.7t to me.
have you registered a DTC code in the bank or are you just looking live at blocks 015 and 016?
Certain cylinder misfires more than others. I can't recall exactly which ones misfire more. Will it help if I find out? TIA
and in each cylinder...so you can determine which cylinder is misfiring. This is only at idle, though.
It takes repeated cylinder misfires and at high numbers for the ECU to register a DTC in the fault code bank (i.e. you can have cylinder misfires for a while visible on block 015 and/or 016 but not show a DTC....but after a week or so a DTC should appear if the threshold has been exceeded).
Let me know what you see in 015 and 016.
tricky1090
9
05-05-2011 02:29 PM
DrewP
08-13-2002 01:07 PM
jlh28athome
06-12-2002 02:28 PM
