Does this air/fuel ratio look right?..........TIA
<center><img src="http://pictureposter.audiworld.com/71155/oldyeller_af_1024.jpg"></center><p>shouldn't it be closer to 12.0 vs. less than 11.0? Where it drops to 10.0 is that an indication it got a little lean or visa versa?
other A/F i have found are more like 12.5 with a similar set up so I wonderd if mine was off enough to bother with tweaking.
further(i.e. a little leaner) Obviously I would need some baseline logs of maybe CF and knock voltages to be safe but would I see any decent hp gains?
"shouldn't it be closer to 12.0 vs. less than 11.0? Where it drops to 10.0 is that an indication it got a little lean or visa versa?"
ys, this is way too rich. you are nearing 9 afr. you should be AT LEAST 11.0 at wot. i wouldnt go over 11.6 on 93 octane for safe boosting. it didnt look like anyone else answered what you wanted. go get retuned.
