does anyone know the amendment to the IC Mister write up for a 2001 and up
I am old badge 2001 but there is a different wire to connect to the injector or something. please advise.
probably will have something comprehensible in ~2 weeks.
the wire mentioned in DonP's article didn't exist in my wiring harness. my recommendation is to remove the connector at one of the injectors and pull back the rubber cover to see what color the positive wire is (mine was brown with green stripe for the forward-most injector on the driver side...not sure what injector # that is)...and then slice that wire in the harness and use an ohmmeter to verify that it's the right one. if it is, then tap that for the controller and you're good to go.
but i trust DonP's test results. the electronics are definitely working, though, since it's draining my reservoir tank automagically.
now it's just a matter of tweaking the settings to get the maximum benefit from the cooling effect from the misters but to not have them on when unnecessary.
THOMAS JONES
New Member Welcome Area
01-17-2016 02:02 PM
Chimpzilla
06-08-2005 03:06 AM
JacobB
06-29-2004 06:54 PM
funkadelic
05-11-2002 03:23 PM
Silvr1.8T
02-04-2001 12:57 PM
