Does anyone know if MTM makes 104 Octane programs..also...
is anyone running AWE Downpipes with the testpipes with an MTM exhaust or just that combo with the reg. cats? Thanks
Don't need a 104 program, just put it in, reset the ECU, drive for 15 minutes :-)
MTM is very aggressive when it comes to timing advancement w/ high octane fuel. Beware, may cause crack(race fuel) addiction, and become spendy!
What do you mean by agressive? I do know Joe Hoppen preety good though so maybe he could help.....
me out I live an hour away from him and bisit his shop often so maybe I can work my way way in to some racing software. as they always say ''its not what you know but who you know''
Well, the motronic system by design will adjust ecu settings based on what it gets back from
its sensors, such as knock, egt, etc - MTM has setup their programs with a pretty aggressive timing advance, in that you'll make a good amount of power, if you're lucky enough to live in an area with good fuel. The chip is absolutely *sick* on 100+ octane fuel. I am not sure a race chip on your stock downpipes, etc would really benefit you due to the increased EGT temps that come with advanced timing - I could be wrong, since I do not know how much 'room' there is for anymore advanced timing. Like I said, MTM has it set pretty good, so the higher the octane of your fuel, the better it runs. I can only speak for the stg3 ecu. Just try 104 with your current chip, make sure to disconnect it, reconnect it - and do not do a throttle adaption.
tommorow at 10:00a.m. my AWE downpipes w/ test pipes will be in then i get the stage 3 chip on....
Friday. Hoppen is only an hour away from my house since im in Naples, FL. i can get up to 110 octane here so yea
Sloooo4esT
Audi Original "S" Cars
05-06-2004 10:25 AM
EmpireS4
17
11-08-2002 03:54 PM
pearl2k
11-05-2002 06:43 PM
b-thumper
08-18-2002 03:28 PM
just got mtm version 2 very happy with it does ne one know if using higher octane fuel will add powe
rvent
07-27-2002 08:33 PM
