Does anyone know the size of this vacuum line and where I can buy a replacement?
In the photo, it's the short line running vertical connected to the brass T fitting.
I'd also need two new clamps.
Thanks in advance.
<img src="http://tychl.txf.com/bg/MVC-001F.JPG">
Thanks in advance.
I'm trying to avoid removing the line. It's torn/cracked, but I taped it and it seems to be holding up. I'm concerned about the car not running if I remove it, and then I won't be able to get to the auto parts store.
I do know that the overall (outside) diameter of this fuel line is larger than the stock lines. It's just that it's thicker (more material) and so the internal diameter is the same (or even slightly smaller). Have to check. It's really cheap though.
