does anyone know where the hood switch is (for the alarm)?
just today the alarm started going off repeatedly.
i got:
01369 - Alarm triggered by Hood Switch
most of the time the alarm does not flash the blinkers, as if a door is ajar. once it armed properly and immidiately the alarm sounded off; that's when i pulled off the code.
is there a way to disable the hood sensor thru central lock programming via vagcom?
TIA.
i got:
TIA.
<center><img src="http://pictureposter.audiworld.com/512/s4_hoodswitch.1.jpg"></center><p>
Something like $5.00 for the part. It's under the rubber corregated pyramid shaped boot.
i couldnt find anything under search. it doesn't seem like a common problem.
well, a few messages popped up with the code, but no one addressed the issue specifically.
IIRC there are two. I may be wrong. Not sure if it matters how you reconnect them, but label them anyway before you disconnect. I'm sure someone can chime in here.
i'm guessing the picture you posted is of a 00-01 i have a 01.5:
<img src="http://dooshorade.home.comcast.net/S4hood0.jpg">
the only thing reasonable i saw was under the latch, where two brown wires go into it:
<img src="http://dooshorade.home.comcast.net/S4hood1.jpg">
<img src="http://dooshorade.home.comcast.net/S4hood2.jpg">
The picture showed the same setup as was on my 1997 A4, I assumed that it was still the same. Sorry and good luck!
tristateS4
02-27-2007 10:35 AM
QuickSilver2
VAG-COM Discussion
01-11-2005 05:26 AM
